Mount error during end of installation
#1
I’m trying to install OSMC 2018-01 on my RPi Zero.
I get this error at the end of installation. I tried a manual mount just before the error popup as well. But no luck.
Log on PasteBin
Screenshot from 2018-02-13 12-20-28
#2
Check the installer has permissions to write to /tmp/
#3
Yeah…
/tmp has permissions 777
OSMC on my Pi after this error - no issues.
But, it only creates 1 partition on my SD card (with the OSMC img).
Is this expected behavior?
#4
Yes, second partition will be created during first boot on the PI.
The 1 boot partition that now should be visible should contain 8 files including filesystem.tar.xz
